Best non-emission carb replacement 1983 5L Riviera
Thread starter #1
dannyboy3
I definitely want to replace my stock emission carb and remove the air pump etc. and all of the mass components-vacuum lines...etc. etc. and clean up my engine compartment-hopefully get better fuel mileage and performance etc. and go with a non-emission carb.
4bl or 2bl as I pretty much just putt around in it and kicking in to a 4bl is not that important to me unless I would loose to much performance.
Can anyone recommend a good replacement carb that I might go with that would fit properly and bolt up/hook up with out to many headaches?
Thanks!!!
LARRY70GS
59
48
Oakland Gardens, N.Y.
98 Riviera, 70 GS455 Stg1
I honestly don't think your mileage will be any better with a carburetor other than your stock Quadrajet. The engine in your car is either the 305 Chevy, or 307 Oldsmobile engine. Both of them are gutless engines, very low performance. It really isn't worth doing anything to them IMO. If I wanted better performance, I would look at swapping in an earlier Oldsmobile 350, or even a 403 engine as that would probably be a relatively easy swap. If you have the 305, you really have the option of any crate engine out of the Sumitt or Jegs catalog. Better performance and mileage if you pick the right one.
Over on www.v8buick, there are 2 guys who specialize in custom building Quadrajets. One is in Connecticut, the other in Texas. I could put you in touch with either or both of them if you like.
143
Quadrajets are the best option for that particular vehicle! Small primaries & huge secondaries are the way to go. Look at the late-mid '60's 4-barrel carbs, a lot of options out there. Don't even think about the Rochester 2-barrel, mileage will suffer.
LARRY70GS
59
48
Yes, the only thing that I would add is that early Q-jets suffered from a poor float design. The 70 and up had stronger floats. The emission carburetors can be re calibrated to be performance units. It involves more than jet and rod changes. like I said, I have 2 guys on v8 buick that do this, if anyone is interested. Q-jets are 750 and 800 CFM carburetors. The 800 carbs had visibly larger primary venturis and were fitted to big blocks.
