Hi Everyone!!
This same discussion has been going on over in the Buick Verano Forum.
Same problems with the Side Detection Module or connection going bad due to corrosion.
I posed the question about doing some preventative measures to keep the corrosion/contamination problem from occurring. The answer is yes, and can be done as a DIY. Probably different remedies can be tried/applied from using plastic tape around the connection to using silicone seal and foam gaskets on the module. Worth giving it a try since a fix after the fact can get pricey.
