Brake pad damage
imidazol97
Top Dog
1,660
127
I got around to taking off the 70K mile ceramic pads from AC Delco on my 03. I thought the outside pad was making an occasional squawk because of the prong rubbing the rotor.
Instead I found the inner pad was bent and the ceramic pad was cracked.
I had no problem with equal braking other than the recent squeak. I had taken the rotors off to have them lightly turned due to a slight warp probably due to hitting water while the rotor was hot last winter/spring. I must have not gotten the pad into the slots correctly when I did the reassembly.
WOW.
http://i86.photobucket.com/albums/k110/imidazol97/DSC09091.jpg
http://i86.photobucket.com/albums/k110/imidazol97/DSC09092.jpg
http://i86.photobucket.com/albums/k110/imidazol97/DSC09093.jpg
701
"WOW" is right, I have never seen a brake pad backing plate warped like that in my past 50-yrs of automotive brake service.
