Broken motor mount bolts. Need info
LMG1438
Buick Park Ave Base 1998
1998 Park Ave ,not Ultra with 3.8 L . The mount that is at the water pump location one bolt broke recently ,the the other one broke sunday .The bolts are the ones that connect the halves together they are vertical ones , not the studs that bolt to the engine or carriage bolts that connect to the frame.I was thinking about using hex bolts , would grade 5 be strong enough to hold?
Thanks
LMG
703
If you are talking about item #36, which is a stud? Are you sure you could replace that with a bolt? If so, grade 5 should be plenty strong enough. http://www.boltdepot.com/fastener-information/Materials-and-Grades/Bolt-Grade-Chart.aspx
http://parts.nalleygmc.com/showAsse...1998&ukey_category=19398&ukey_trimLevel=15566
LMG1438
Hi, thanks for your reply HotZ28, the item #36 has been discontinued so i used the hex bolts 12MM / 1.75
melmann423
Can a supercharged motor and transmission work in a base model buick park avenue 1999
703
http://
Yes, as long as you install the complete wiring harness, PCM & CV shafts from the PAU.
703
I need stud num 22 where can I get it
Some well equipped hardware stores have studs in stock, but that particular one may be hard to match! It may require a visit to a local machine shop to match the stud size/length & threads.
TIFWAL79
1998 Buick Park Avenue
Help ? Looking for part # 11. Transmission Mount for a 1998 Buick Park Avenue, Base model. Images attached. There is nothing that looks like this part anywhere online that I can find.
