Dinosauze
- 0
- 1
- Regal
Does anyone know where the throttle body is on a 2015 Buick Regal getting an P1101 Code, and I’m pretty sure the tb is gummed up can’t seem to find it though
Well, changed Maf sensor I know what I’m doing it’s been known to sometimes be Tb I just can’t find itNot sure on how you came up with the TB if you don't know where it's at and you didn't mention what engine. But here's the description of the code which may be something to review before getting into the possible repair.
P1101 OBD-II Trouble Code: Mass Airflow Sensor Out of Self Test Range
P1101 means there is an issue with the mass airflow sensor system. It is likely due to a faulty sensor, bad connectors, or an air leak.www.yourmechanic.com
Thank you so much man!TB is Part# 541
