Buick Skylark dash pad ?
JGT
1968 Buick Skylark
How do you remove and install a dash pad on my 1968 Buick Skylark
JGT
1968 Buick Skylark
I noticed some of the threads say there are nuts while others say there are studs that pop in. Any other advice might help
2,781
Signing up to V8buick.com might be the best route as someone there may have addtional information. If it's a long term project a GM body manual might be helpful to obtain.
LARRY70GS
327
Oakland Gardens, N.Y.
98 Riviera, 70 GS455 Stg1
I believe it is very similar to the 70-72. There are 4 studs with nuts on the passenger side. You get to them by removing the glove box liner. There are also several screws that go up into the dash pad from the instrument panel. Then the dash pad pulls off via several spring clips. There are better instructions in the 1968 Chassis Manual. Relatively inexpensive on Ebay,
You need one.
In the meantime, the 68 Chassis Manual is available on Teambuick.com if you sign up. Or, if you send me an e mail to Larrymta@verizon.net, I'll send you a pdf of the dash section.
JGT
1968 Buick Skylark
Thanks for the information.I went ahead and ordered the chassis manual on eBay.
