Buick Verano 2.4
OneStupidChoice
Verano 2.4
It's possible but I doubt it. Have you scrolled through the sub-sections to make sure? What sort of mods are you wanting to make?
I’ve looked into everything from tires and suspension to engine performance including remapping the ECU/chipping and even looked into turbo kits. I know if I was to break down the heads and completely build it up from scratch it would be costly but I want to build the Verano due to the fact that it would be unique
Skylarkin'
342
77
St. Louis, Missouri
2015 Buick Verano Turbo
Might be cheaper in the long run instead to look for a Verano Turbo at a junkyard that's been rear-ended and take its 2L Turbo, transmission, final drive and ECM software.
