Cadillac XTS front brake mod
Alacran
I wanted to post on here that i was successful in eliminating the soft spungy brake pedal feel by swapping over to the Cadillac XTS Brembo brake set up. I changed everything from dust shield to the brake hose. everything bolted up to the spindle just fine.
The hardest part was replacing the wheel hub on each side. I had two spare on standby just in case and i used them both because the work required to pull hubs off of the spindle. I have to go in and recheck Torque on the bolts and lug nuts but i drive this car daily and the brake mod works great.
Rich B.
99
Minot, ME
Always excellent when a plan succeeds of coarse but if you had spongy brakes? I’d say you just had air in the lines someplace, brakes aren’t spongy normally; must of bled them good anyways. Lucky to still of maintained wheel/rim clearances.
Alacran
@Rich B. It is well document in many automotive reviews for the 2012 Buick Lacrosse, cars.com calls it "Mushy brakes". I am describing an upgrade in my post and not a component or system failure.
Bhodi's Buick
122
Lake Michigan's South Shore
'13 LaCrosse 303 HP V6
Good to know the Brembos fit and work. Thanks.
I got the 18" Chromies, looks like you have the larger Deluxe 19" wheels.
Also looks like you got the parts used from a bone yard.
Few questions for you:
You think the larger brake set would still fit with an 18" wheel ?
How much $ did the parts run you, and How much $ do you think you saved compared to buying all the Parts new ?
Alacran
@Bhodi's Buick - i did not try an 18" wheel.
I purchased a used Buick spindle to do my mock up before doing the work. that is how I found out what parts i needed and if my wheel would work.
Overall the cost with bolts (hub and caliper bolts), both dust shields, calipers, rotors, brake hose, brake pads the cost is around $700.00. I created a spreadsheet but i am missing the cost for the bolts.
Anyway - i bought new and used where it made sense. Bolts, pads, dust shields, hubs, and brake hose are brand new. I saved on used calipers and rotors. The rotors are GM factory with high tech material that you cannot
Daniel J Gilson
Deerfield Mi
2015 Lacrosse 3.6 awd
So the wheel bearing assembly did not work because of the offset? The bolt pattern is the same or are you talking about the caliper mounting ear on the spindle?
