Cargo Net trunk latch cover
Manolife
2008 Lucerne
I just became the owner of a 2008 Lucerne CXL, I found 3 inches of water in the spare tire well. I think I found the leak, but I’m not sure I have the correct knobs and mounting hardware. Can someone send a photo of the cargo net installed please? I find a bolt on the floor to attach a cargo net knob, a 2nd is the top bolt of the tail light which protrudes beyond the latch cover. I see a 3rd location where there is a hole in the latch cover below the tail light bolt and the metal behind the cover has a keyhole shape but no means of attaching a knob. It seems the latch cover should have a fastener at this location. What am I missing? Thanks
850
Unless you have a sunroof, the most common leak is in the bumper area that will fill up the spare, TSB on it. Here's some info on that:
2007 Buick Lucerne, trunk leaks. Seal looks like new
On the cargo net hold downs, 2 are on the trunk floor. 2 are on each side by the taillights 1 up at the top and 1 down near the bottom. They do become loose if removed to many times as they are a push on. You may try some RTV silicone and leave it set up for a day, but if need to get to the spare or lights it can't be a permanent fix.
Manolife
2008 Lucerne
Thank you. Yes that is the water problem. I found it but have not repaired yet. From your diagram I’m missing part #13 and a couple of #12. Can you provide the GM part numbers? The diagrams I found do not have either shown
850
Manolife
2008 Lucerne
Here's the page on part numbers, but it may be a used / eBay part as some Lucerne parts are getting difficult to find, check the GM parts site but at least you won't be surprised if not there.
https://buick.catalogs-parts.com/#{client:1;page:part;lang:ru;family:lucerne;model:49037-2008;group:0-0-1608642826;subgroup:0-1624020498-0-0}#2
Thank you for the link but it doesn’t work for me. I tried looking through the diagrams but couldn’t find it. Can you provide the category or part numbers?
