Coolant Flush DIY 1999 Buick Century 3.1L engine
aya7019
1999 Buick Century
Good Afternoon. I am wondering if anyone has done the coolant flush themselves and where is the engine block drain plug. I have found the petcock for the radiator however having difficulties locating the block drain plug. Only got about just over 4 litres of coolant from the radiator. The capacity is about just about 10 litres. Any help would be appreciated
Waiex191
54
Poplar Grove, IL
2000 Century
Based on rust, I was afraid to pop off my block drains. I had the manifold off, so I siphoned out from the head coolant passage. I also vacuumed out the heat exchanger, as well as draining the radiator and reservoir. Close enough for me!
Pedal Commander
