Cruise Control On/Off Switch
Thread starter #1
teryan
LeSabre
Own a 2000 LeSabre.
Cruise ON/Off switch failed, won't stay on. Have new switch, but when I remove the old switch from the steering wheel, the wiring is incredibly short making replacing it seemingly impossible.
Anyone have any experience or tips they can share ?
thanks
terry
TerryP
I'm guessing it's on the steering wheel like the 2004, if it's like the radio controls then you can try using needle nose pliers to hang on to the wiring while you plug it in. I was able to pull the wires to get me a little slack on the radio controls, but they were tight.
12
2000 Lesabre Custom
Does the old switch light up when you press it in but won't stay in? If so, just put a drop of super glue on the switch and hold it in till the glue dries. Then your main switch is always on and you just turn off the cruise with the brake.
