Alpha one
- 0
- 1
- Buick
My 1995 LeSabre misfires on cylinder #4. In fact it almost never fires. The other 5 never fail to fire.
But the spark plug has spark, and the injector sprays.
It has new wires and new spark plugs, new coils and ignition.
Fuel pressure OK.
I switched injector with another cylinder, but #4 continued to misfire.
The car starts every time and it will drive places. I just don't want to until I fix that problem.
I did an incomplete cylinder compression test:
I attached a compression gauge to cylinder #4 and started the engine. I got 62 pounds pressure (Average, I guess).
Then, I connected the gauge to cylinder #3 and started the engine. I got 67 pounds pressure. A difference of 5 pounds.
Any idea why #4 doesn't fire? Could a little lower compression be the problem?
Thank you,
Antonio.
Fuel pressure OK.
Thank you,
Antonio.
