Disable Automatic Stop/Start
hunterwh
7
Regal Tourx
Hi all! Just bought my Tourx and love it! The only thing is I want to disable the automatic stop/start. I saw this is available aftermarket. Would this void any warranty though?
Anaduff
Associate Member
642
93
St. Paul, Minnesota
2019 Insignia GS
Short answer, no.
(Assumption is that you're talking about the 'SmartStopStart' module.)
There may be some (although none have been spotted on this forum) who will argue that since this module attaches to wires that run to the body control module, and that the body control module is attached to the GM-LAN bus, which also connects to the engine control module, the transmission control module and sundry other modules; therefore its installation will void the warranty for everything on the car with the exception of the front license plate bracket--and then only for those states that don't require it.
Further info can be found by searching this forum.
L J
546
Regal TourX
You will have no GM coverage on the module, that disables your ASS !
Just pretend you lived over 100 years ago, and instead of turning crank to start car.... just open hood.
PS The module is worth it, puts you in control.
BoostedRegal2.0
670
The warranty can not be voided. They can deny coverage of a repair if they can prove an aftermarket part caused a part to fail.
L J
546
Regal TourX
Buick dealers are making money installing the same module, it is easy to remove without a trace if needed.
Now if you disabled ASS thru a tune, that is different ....on possiible problems with GM.
hunterwh
7
Regal Tourx
Who would I ask to do this? A mechanic at a Buick dealer?
2,766
Here's 17-18 Regal instructions.
  • website_buick_regal_instructions_ver._1.0.pdf
L J
546
Regal TourX
I put in myself, but service manager at delivery dealer said they had installed them. No doubt for 5 min of time, they get minimum of hour labor.
Uniqez
276
2018 Opel Insignia Country Tourer with Buick steering wheel, HMI and floor mats
Can you gentlemen confirm that remote start is working with this by-pass?
Idano
164
Preferred Red Needle TourX
$140 so I don't need to pump the brake pedal when I stop ?
SS-Stealth
14
2020 Regal Tourx Preferred
I was told that all you need to do to disable it is to pop the shifter into manual mode. Does that not work on some trim levels?
rjw
21
2019 Regal Sportback
Actually, rangetechnology offers a device that plugs into the OBD port underneath the steering wheel. It's $190, which is a little more than the start/stop device, but it is much simpler to install - just plug it into the port. I have had mine for about a month now and I love it. And it does NOT affect remote start like the start/stop device does. Better yet, you can just unplug it before you go to the dealer to avoid any possible warranty issues.
hunterwh
7
Regal Tourx
awesome! I am going to check this out. My major concern was with the warranty
