Driver's is door is locked, won't open
Canada2
Sorry I had this posted in another thread but will post it in here because this is a serious issue and this does affect all Buicks after 2002
Unfortunately it's not a problem in the DIC it's in the actuators according to a good source the actuators are only good for 77,000 cycles then they fail sometimes less than 77,000 cycles. Buick has known about this problem since 2003 and it affects all Buicks. To me this is a very serious safety issues. If in an accident with serious injuries or a fire was to happen and you can not get out of your vehicle your done. I have filed a complaint with the Canadian Safety Board that this should be a recall. and would advise all Buick owners in the United States to do the same. This issue affects all four doors, currently I have two doors that won't open on my Buick Allure, the same model as the Buick LaCrosse in the US. To fix all four doors will run you around a thousand dollars, Sorry for giving you the bad news.
Rossland
2016 Buick Lacrosse
I also had a failure of a door lock, but it was a different problem. The door would not unlock with the button on the outside door handle. I could unlock it with the key, and could always unlock it from inside. The dealer replaced the outside button under warranty.
08lacrosse
08 lacrosse
Hello BuickLacrosse,
We are terribly sorry to hear that you are experiencing these concerns with the door of your Buick, and sincerely apologize for any inconvenience this concern has caused you. We understand that you are currently seeking advice from other users on the forum, however please know that our team would love the opportunity to look into these concerns further and help determine your best course of action moving forward. If this is something that would interest you, feel free to send us a private message with your full contact information, VIN, vehicle mileage, and the name of your preferred dealership so that we can proceed. We look forward to hearing from you soon.
Sincerely,
Steven A.
Buick Customer Care
Steven A at Buick customer care. I am inquiring to see if you can assist me. I have a 2008 Lacrosse and had the door actuator fail on the drivers door several years ago. I repaired this and then about two years ago, the front passenger actuator began to fail. Unfortunately I did not repair it when I could open the door and am unable to open that door. I am hesitant to use the car in case the drivers door fails or in an accident on that side and can’t exit the car. This is a safety issue. Any help from Buick. Tim
Clydeman
A couple pics. If your door won't open but you can get the panel partially off then you can reach in and unlock by moving the small lever up that is attached to the small rod which goes to the spot where the key goes into the door. In the first picture you can see the small rod that attaches at the top with a blue clip. That is the rod and lever that must be moved up to unlock the door. The rod which is in the yellow clip comes from the outer door handle. The cable which attaches to the latch with the blue collar comes from the inside door handle. The other rod with the four bends at the bottom is the door lock button. I'm not good at typing but I think if someone looks at the pics it becomes clear how this thing works.
Great job with the photos, having the same problem with my 07 Lacrosse
Rich B.
50
Minot, ME
Some great info here, again something I never gave a second thought about. The driver side lock should open with key, maybe it's a remote issue in some instances?
buicker
montreal
Buick regal
It just hapened to me tonight driver door does not open.allure 2008 110,000 km. Had to change right rear door actuator last year it would lock and unlock by hand but not automatically. Will have to check it this week-end.
oldschool
7
Barrie, Ont
'03 Buick LeSabre, '07 Allure CXL
These must be the worst door latches ever designed for a car. Once again I can't get the drivers door open from the inside. Will try lubricating the latch tonight when I get home but will probably have to replace it again. For the third time. Will never buy a GM again.
