Driving Range on your Buick Century
century101
century 2001
Hi everyone! New to the forum. I'm considering buying a 2001 Century as my daily driver, but i'm wondering what the driving range is like. I see that it has a 17.5 gallon fuel tank, so how many miles can i expect out of a full tank of gas? How many much driving range do you guys get? Any insight on this would be great! Thanks
hitshane
9
Saint Petersburg, FL
2005 Century Custom
A quick Google search returned
20 city / 29 highway, 17.5gal tank...
350 city / 507.5 highway
Probably somewhere between 300 and 400 miles with properly inflated tires and no engine problems.
Just remember you're getting into a 20 year old vehicle it's going to need gaskets, hoses, vacuum lines, filters, tires, brakes. It probably needs a coolant flush and a oil change. The catalytic converter is most likely shot. The fuel pressure regulator is about to go. The thermal bypass pipe is probably rusting through. The air conditioner is going to need a resistor pack. The power windows are going to stop working if they haven't already. The speakers are probably dry-rotted and the stereo most likely doesn't work.
Unscrew the oil fill cap off the engine and the radiator cap before you buy it. Make sure there's no white looking goop on the oil cap and make sure there's no oil looking goop in the radiator cap or that means it needs a new intake manifold gasket and that job costs almost $1,000.
Now it's a pressure system so once you remove the radiator cap you're going to have to find the coolant bleeder it's a little screw, then you're going to have to run the motor and open the bleeder up carefully to let the bubbles out. Once the engine gets up to temp you close it off when water starts coming through and the bubbles stop or you're going to have overheating issues.
The relay boxes in these cars if you live in a hot area the relays tend to separate from the plastic inside the box and the first issues you normally get is the cooling fans not turning on and engine overheat problems. Mine was like this so I would have to drive with the AC on all the time because having the air conditioning on forced the fans to turn on because they wouldn't do it by themselves.
I'm not trying to discourage you I'm just telling you what you have to look forward to so unless you're buying this from Grandma and it only has 20000 miles on it then you need to be ready to take care of it. Now if you go through and replace all the hoses and vacuum lines and fuel pressure regulator and all of the various filters all over the engine and give it some fresh coolant after draining all the twenty-year-old stuff out of it then it will probably be a good car.
I would also like to add that for about $3,500 you could find a 10 year old Corolla that gets double the gas mileage and is a lot cheaper to repair.
I currently have a 2000 Buick Regal LS in my driveway as a backup vehicle for my wife and I when we are servicing our other vehicles. I had a 2005 Buick Century that I completely fixed up which of course someone hit me in an accident and totaled it right when I got it to tip top shape.
century101
century 2001
Wow. Thankyou for the detailed reply. I am aware of the intake manifold issue. The particular vehicle I'm looking at is a 2001 with 124000 miles on it and comes with 6 months warranty. The exterior and interior is in excellent shape (from the photos I've seen). I am going to test drive it this saturday and I will make sure to look at oil cap and radiator cap for any signs of contamination. I drive 97 miles a day to work, so I'm looking for something comtorbale on the highways, thats why I'm considering this buick. Thanks again!!
ceTNury
2003 century
I've been going crazy trying to chase down this fan issue for a couple years. If it's the relay box I owe you a beer.
