Electra 65 4 door hardtop
Thread starter #1
7
The Netherlands (Europe)
Not yet!
Hi,
I’m thinking of buying an Electra from 1965. Current owner claims that the engine and transmission are revised.
What should I keep in mind and what do I need to check before buying? (Weak spots)
Since I live in Europe I don’t know what the availabilty off parts is in the US.
Regards Erik the Dutchman
159
Define exactly what "revised" means?
Drive train and suspension parts should not be a problem.
Interior and exterior body parts might be a problem.
Like any used car, especially 53 years old, have it checked before buying it.
Thread starter #3
7
Not yet!
Thanks for your reply. Transmission is done in 2016, overall overhaul. The engine, 401, in 2015 all pistons and bearings are replaced. A new waterpump is installed. Het blok is geboord, koppen gevlakt, nieuwe waterpomp. The ignition is replaced by an electronic system and a new Edelbrock carburator. Also a new oilpump and the radiator is upgraded for extra cooling power. The rear axle has an other differential. So far I have only email contact with seller.
159
Beautiful looking car. Hopefully the current owner will send you pictures of the engine compartment and the underside of the car including frame and suspension components and exhaust system.
Thread starter #8
7
Not yet!
One picture of engine. Car has had an anti rust treatment (dinitrol). Pics of underside were not very clear.
159
You do realize there are indications that the engine has been modified.
1. Air cleaner assembly not stock.
2. Fuel pressure regulator mounted on right side inner fender.
3. Unknown box mounted on left side inner fender.
4. Spark plug wires.
159
It could be as MSD box, cannt see clearly from the picture. The modifications themselves are not bad but it may indicate a some what aggressive driver owned the car in the past. Again I encourage you to have the car checked by a mechanic before purchasing it.
1,377
353
One more item from the engine bay photo that it is the single master brake cylinder which is period correct but, my own opinion, can be a issue if any of the brake lines go out. It's pretty much no brakes except the emergency brake. See if all brake lines, wheel cylinders and master have been rebuilt or replaced. In the same group as steering components, its a bad day if these go out when you are driving. Reproduction parts are here in the USA but can't know how easy they are for this year over there. Good luck and hope it works out.
