Electrical problems
Ultra rider
1996 Buick Park Ave Ultra
So I have a 1996 Buick park avenue ultra and I'm having an electrical problem. I shut my car off and remove the key from the ignition and I can still turn my heat on and this problem is draining my battery..... HELP ME PLEASE!!! my car has 98,xxx miles
Alan 55
84
Florida
lf I understand correctly the blower motor continues to run with the engine off and key removed. Is this the case?
If so, this is a fairly common issue and the faulty part is likely to be the blower motor resistor. To keep your battery from going dead you can remove the negative cable from the battery until the resistor is replaced.
Ultra rider
Yes the climate control stays on as if the car is on and my warning lights for my bulbs all lit up
Alan 55
84
Florida
This sounds a bit different that what I have experience, perhaps someone will chime in to assist.
85ltdt
Virginia
67 Skylark, then 76 Skylark,90 LeSabre,83 T-Type, 85 Limited T-Type, 98 Park Avenue, now a 96 Ultra
Googled your issue. I also have the 96 Ultra but don't have that issue (yet). Seems there's a short between the power supply wiring allowing a ground to the circuit. Multimeter and time to trace it down from this post:
AC/Heater Blower Motor Won't Shut Of
Also from the forums: HVAC fan won't shut off
Drakito
65
Southern Utah
2003 Park Avenue Ultra
Quick check, open the passenger door and see if it turns off. If it does, the drivers door switch is bad. If it doesn't, you will need to work through 85ltdt's fix above.
Pedal Commander
