Fast talker
Megolfer
2021 Envision
2021 Envision. Love it. But the voice in the navigation system talks so fast I sometimes can't make out the direction. Like, all words strung together with no pause: ""Takeexitg209oninterstate75bearleftattheintersection."
Now, when I look at the Nav menu, there seems to be a setting for voice speed, but it doesn't turn on when I press. Is this because the app is only available on top of line models? (I'm not really sure what model I bought...the salesman was an idiot and explained very little. My spouse liked the color. So...)
1,261
When you try to adjust voice speed, is the engine running and in Park?
The window sticker will tell you what trim you purchased.
Regal LTD Coupe
308
It likely just resembles the style of speaking where it was built. You'd be best to dump it while you can because it's a disposable car that will be a massive and worthless headache later. Sorry to be frank but you obviously did not do any research on this one whatsoever.
mitchflorida
Active Member
530
152
South Florida
Are you feeling okay?
G-119635
Wow, so spending the time and doing the research to only wind up purchasing a used 1993 Buick Regal Limited says something about your decision making process. So you'd be best to dump it while you can because it's a disposable car that will be a massive and worthless headache later would also apply.
