Frame Rust - Left Front
abizzle
357
86
Baton Rouge, LA
2018 Regal Sportback Essence
Has anyone else noticed rust on the frame near the front of the vehicle? I found some at the very tip of the frame on the driver’s side. I wish I could take a picture, but it’s obscured by the large, plastic cover beneath the radiator. I have circled the area on the picture below.
I will try to get a better look at it this evening after I service my floor jack. It needs some hydraulic fluid.
Would anyone mind looking at their frame and see if you notice any rust in that area?
Thanks in advance.
abizzle
357
86
Baton Rouge, LA
My car has been in MN for 3 years...I would be shocked if there wasn't rust.
I know my car was in Michigan from December 2017 to March 2021. Living in the South, rust is generally not an issue. Just wanted to know if I should be concerned or not.
RegalMN
132
Minnesota
'18 Regal Sportback Essence
Is this an area that can bee seen by crawling under the car without a jack? If so I can take a look at mine when I get home.
abizzle
357
86
Baton Rouge, LA
Yes, but you may have to remove a couple of the 6mm screws holding that plastic shroud up. If you don’t wanna get into all of that I understand. I was planning to jack it up this evening so I could get a better look at it.
Speaking of the plastic shroud, it has 6mm screws across the back side and what appears to be a special type of plastic fastener across the front. I wanted to remove the whole thing, but those clips are in there tight.
