Front Grill Emblem
rgrove
2014 Buick Regal T1
I have a 2014 Regal. Do they make a colored front Grille emblem? If so where can I purchase one?
Eilustre
21
Maryland
16' Buick Regal GS "Ebony Metallic" & 17' BMW M3 F80
i don't think they do, i know the newer models of the buick line ups have the tri-color emblems now (buick lucerne)
Anaduff
55
St. Paul, Minnesota
2019 Insignia (Mostly)
Don't know if this helps--the badge mounted on the front grille of a 2018/19 Regal is 5.75" outside
diameter, and I'm very sure you would have to remove it (the actual badge) from the mounting
plate it is attached to (GM part 39104440 which is the whole assembly).
MikeC725
27
48
Northville, MI
2014 Regal GS AWD
2014's did not come from factory with colored emblems. There was a member here who was selling stickers for the front, rear and steering wheel. Do a search.
Eilustre
21
Maryland
I know I can swap out my emblem on my GS and replace it with an 18' GS tri color w/ Adaptive lane change and cruise. I just ordered mines off GM for $300
510
You can check a new version from any current Buick to see if a size is a match, but it may require a modifications to the insert area of the current grille. There emblems on GM, Ebay and aliexpress, some back lighted LED are out there if so inclined.
