Fuel Gauge Problem (I've done everything!!!)
ilir9b
Hey guys!
I have the ubiquitous fuel gauge problem in my 2003 Lesabre Custom. It goes up and down and there's no pattern - it doesn't matter if it's full or empty or half full.
I've changed the whole fuel pump a while ago. That didn't do anything. Just this week I pulled the cluster and changed the stepper motors. I thought this would finally do the trick but nothing happened. The same problem persists.
Does anyone have any other tips that can actually make this thing work?
Please help! This is driving me nuts.
Thank you, as always!
imidazol97
Top Dog
1,534
59
48
Haven't people reported the connections at a weatherproof connector for the electrical lines to the sender were the problem or a broken wire making and breaking contact along the run of wire.
ilir9b
Thank you for the reply, I can't find that info anywhere. Or a way to check for it and let alone fix it.
Anyone else have any ideas or tips?
torres7
20
Lincoln Nebraska
Buick RMW
When you say the whole fuel pump I assume you put in a new fuel level sending unit too, correct?
ilir9b
Yep! Sure did.
It wasn't the OEM or even the most expensive pump out there but I figured it would at the very least give me some different issues and not behave exactly like it did before with the old pump and sending unit.
W.Lasabre
9
2004 Buick Lasabre
I'm going to try and ground off the harness at the pump and see if snything changes. Im having the same issue , classic lasabres
hawgfan
2001 Lesabre, 2007 Lacrosse
I had a problem with my 2001 LeSabre. No reading on gas gage at all. Replaced broken right side tail light, gas gage works. Maybe gas gage sending unit and tail light share a ground.
