Gas gauge all wonky
TerryP
This past weekend we went camping and loaded the 2004 LeSabre pretty heavy the previous week. It was squatting pretty good and after driving it all week, I noticed that it was still on 1/2 tank when I filled it up (which took 10+ gallons) and the needle took it's own trip into another dimension and ended up pointing straight down. It does move when I turn on the key but still ended up pointing South.
After running about 200 miles or so the needle started moving the temp gauge , they kept jockeying for position on the trip back home and the gas gauge now ends up pointing closer to the E but under it (not where it's supposed to be when it's Full.)
Now the temp gauge looks to be pointing in the correct direction but not the gas gauge.
Can I pull the face off of the bezel cover off of the gauge and move the needle when it's Full? or will I not be able to touch the needle? Any ideas on how to fix this?
*** This is the pic I took the morning after I had just filled it up ***
TerryP
Here's a few ideas, can't say if they may work for yours or not.
OMG, that second video sounds like a guy but MUST be a woman, I've never heard a man talk THAT much! Video is twice as long as necessary. His stand-up routine is terrible!
509
LOL, yep there's some real interesting ones I've seen, thank god for mute and fast forward. I don't do them as my mom said I have a face for radio:cool:
TerryP
OK, so I was finally able to get some magnets but they didn't have ANY effect on the gauge, the needle didn't even quiver! Do I need rare earth magnets to do this? Anyone else done this?
509
I just found the links and haven't had the need, greatfully, but it may need more pull then a refrigerator magnet. If you get a clear plastic cup and a sowing needle estimate the distance of the dash plastic to the gauge it may tell you if it's strong enough to explore. I've had rare earth ones where if you put them flush on a piece of metal you needed a vise grip to pull it off LOL, so I'm a little cautious with those around electronics.
TerryP
I just found the links *snip*
Was there supposed to be a link there?
I would think that these are strong enough but like I said didn't even make the gas needle quiver!
And this is about how far I have to be to get it to move that paper clip, maybe that's not close enough!!
