Gas tank filler pipe replacement 2001 LeSabre
G-527465
Is it possible to replace gas tank filler pipe on a 2001 LeSabre without dropping fuel tank?
97PA
30
1997 Park Avenue
I did it on my 2001 LeSabre without any problems. You need to take out the screws holding the filler neck, disconnect the ground strap (good luck not stripping or breaking the bolt) and loosen the filler pipe hose clamp to the fuel tank.
Carleton
LeSabre
Congrats on replacing the gas tank filler neck on your 2001 LeSabre without having to drop the fuel tank. I have the same year and model but have been told by two Buick dealers that dropping the tank was the only way to replace the filler pipe.
So, for starters you said that you need to take out the screws holding the filler neck. Other than the two screws which seem to be part of the door hinge mechanism on the gas cap compartment itself, I can't locate screws securing the filler neck unless they're located under the gasket around the neck itself.
Once the screws had been removed, did you then disconnect the filler pipe (plastic piece on my LeSabre) from the adjoining rubber piece leading to the fuel tank? With the driver's side rear tire removed, I found an access door in the wheel well with an easily removed cover that revealed the clamp securing the connection of the two pieces (plastic and rubber).
Once the clamp was off (assuming my assumptions are correct and you had enough room to work with the clamp through the access door), could you then pull out the filler pipe through the opening at the gas cap housing? But this whole procedure depends on first removing the screws securing the neck, which I have not been able to see.
97PA
30
1997 Park Avenue
It's been a few years (2011) since I did this and I sold the car back in 2017 but I know I had to get the filler out from the inside of the fender. I looked at a picture a replacement filler neck on RockAuto and it has a larger round plastic flange (no tapped metal flange) on the filler to seat against the metal housing inside the filler door. I would disregard my previous post about the screws inside the filler door area. I did remove the left driver's side tire and loosened the clamp to the filler pipe where it attaches to the gas tank, as this is the only way to get the wiggle room needed. I pulled the filler after removing the gas cap from the inside of the fender by bending it downwards. There's just enough clearance to get the filler to clear the inner flange and remove it. I wish I had to car to clearly remember the procedure but I know I was able to do it without removing the gas tank, which my local GM dealer was surprised when I told them.
Carleton
LeSabre
Do you remember how you installed the new filler pipe? Was it through the opening in the gas cap compartment or did you have to do it from inside the fender (were you able to get to the connection of the filler pipe and the pipe leading to the gas tank from inside the fender to reconnect them)?
97PA
30
1997 Park Avenue
I had to install it through the inside of the fender and it took a little wiggling to get the smaller tube at the end of the filler pipe to get into the fuel tank. I ended up repairing my filler pipe, as I didn't want to pay the over $400 dealer price for a new one and no aftermarket pipes were available back in 2011. I used JB Weld to secure the outer steel flange which had come loose and was causing a P0440 code (large leak). I posted my repair on another Buick forum site and several others were able to fix their filler pipes without having to go to the dealer.
Waiex191
70
Poplar Grove, IL
2000 Century
I have this repair coming up on my 2000 Century. I figured I'd harvest one from the junkyard, clean and fiberglass it up, then replace it. This would both let me practice the job and be able to make the part ready ahead of time.
Carleton
LeSabre
It is not necessary to drop the tank on a 2001 Buick LeSabre to replace the fuel neck filler pipe in spite of what a dealer may tell you. A local independent garage replaced mine in about an hour, charging me $90 labor and $510 for the pipe. But if you're going to do it yourself you will find lower priced pipes online. For me, $600 was far better than the $1500+ two Buick dealers quoted. It seems the dealers have found a nice way to maximize their profits at the expense of the customer.
By the way, my original problem as diagnosed and confirmed with a "smoke test" was a vapor leak in the filler neck and along the fuel cap. After about 35 or so starts, each with sufficient drive time, the "Check Engine" light hasn't came back on again so I might be OK as far as the leak goes.
495
Dealer profits are not necessarily made from selling vehicles! The profits (80%+) are mostly made from the service center and parts!
