GKN Twinster
IanMitch
44
1979 LeSabre, 2010 Enclave, 2018 TourX
I'm curious and don't really care to experiment or experience first hand. If you go aggressively into a corner but not under acceleration, does the GKN system put power to the appropriate back wheel to help you through? If not - are you better off accelerating through so the outside rear wheel is powered? Just curious. I've watched a couple of videos but I'm not clear on whether the car will accelerate for you.
JoeBlog
39
Wichita
You’ve got me thinking. The other day, I entered a downhill grade off ramp a little hot. I’d say I was going 55 thru the turn while coasting. It got ahead of me just for a second, and I got on the brakes. I noticed a light coming on in the DIC just left of the gear indicator and right of the odometer. It was an icon of a gear. I can’t find any reference to it in the owners manual, nor does it illuminate when in accessory mode. I’m wondering if the GKN system was telling me something.
IanMitch
44
You understand exactly what I'm asking. If you coast quickly or too quickly into an off ramp, what will the car do if the driver doesn't do anything. Apparently it will engine brake a little by holding in gear. But is the GKN otherwise inactive - and is the driver better off powering through and getting the benefit of the AWD to kick in.
mike69440
299
2018 TourX Essence
I've slid around on some muddy dirt roads and last two days driven (& played) in snow and ice storms. So much for April!
I have not overcooked a curve on dry pavement, (yet). When in doubt, I say just give it a bit of throttle.
GKN system is weird, I haven't really figured out just how it behaves. I'm still learning communication between man and machine.
My Subaru's stability control is straightforward, the Buick's is more complicated.
justiz00
42
Tourx
The gear comes on when off the throttle going almost too fast around a curve. I experience this when taking winding turnpike off ramps here in OK.
garbageguy
36
Regal TourX 2019
Great question, is the answer to stay on the throttle? I like that one.
Last week , had my first emergency maneuver in the TourX on a windy Adirondacks road - so glad I didn't hit those animals. I know shouldn't have tried to avoid, but the car handles better than I expected - I think no throttle or brake applied, not sure if GKN did anything
BahamaTodd
3.8L Member
325
201
Palm Beach, FL
2018.5 Regal GS
No, the system will not accelerate the outside rear wheel on its own. All it can do is engage the clutch on that wheel. Its still up to you to input throttle to benefit.
L J
200
Regal TourX
Need to experiment in empty parking lot, see how the AWD behaves in rain.
Remind me to put on my to do list...will put right after, start my to do list.
mike69440
299
2018 TourX Essence
