heated mirrors
647
It's not plug and play. You will need to check the current door harness has the addtional wiring for the heated mirrors, this you will need to find out. Then you'll need to see if that option is available in the BCM, Tech 2 or dealer trip. It works off the rear window defog control.
skatinnatin
Rotterdam, NY
2004 LeSabre Custom
I can pull the door apart, I was going to install new front speakers anyway. Is Tech 2 a tool/scanner I can buy? I'll try to Google it and see what I can find out about it. Thanks!
647
A TECH 2 will turn your car into a brick very fast if you don't know what you are doing, it's a GM based programming language.
