imidazol97
Top Dog
- 1,786
- 186
- 63
Which green coolant do you recommend for the aluminum that's different than the DexCool formulation NOW and the Prestone Mixes with All Types which is the same formulation that last time I checked the MSDS.
I'm not convinced after the initial DexCool formula change to a different oxidation inhibitor that the shrinking of the seal strips in the lower intake gaskets is anything but a design problem.
Since the vehicle has DexCool in it, for someone at home it's almost impossible to remove all DexCool to put in a complete change of another supposedly "better" choice without residual DexCool in the block or heater core or radiator. I'm thinking of the typical person using a garden hose in their driveway.
After 84000 miles, any supposed damage due to a supposed DexCool formulation flaw or gasket material design problem has already been done.
If I were the original poster, I'd look at the character of the DexCool in the reservoir tank. If it's clouded by oily sludge, then I'd do as complete a drain and refill as possible.
Be aware, I believe GM was still putting in the pellets of ground pecan shells or some organic material such as that which would expand where there was a seep and block the seep. They were and I guess still are available or can be purchased in other brand products to seal seeps if possible. (Bars leak that is a powder in a tube I believe is the same material. Probably same as supplied to GM for their pellets, in my guess.)
Poster may need be careful that a slight clouding in the reservoir tank is not from the sealer.
Either way a drain and fill with 50/50 or of pure with half distilled water can't hurt to refresh the chemicals if the original is still in the radiator.
