Help! 2013 GS sputtered and won't start after fill up - coincidence? Bad gas?
Everyshadeofblue
San Diego, CA
2013 Buick Regal GS
Hi all!
I filled up my 2013 GS (40K) with Mobil 91octane today and then washed my car in the gas station car wash. Stopped and dried it with no problems and then drove a few miles back to work. I just got back in my car and it sputtered and stalled and won't fire back up at all. I double checked my gas receipt and I did put in 91 octane (at $3.99 a gallon!) fuel and didn't mix up the diesel pump. The battery was replaced a year ago and I do not think that is the problem. Any ideas? I will get it towed in tomorrow morning.
Thank you for any advice!
Jeff
CLE12GS
146
Cleveland
2012 Buick GS
Is you Mechanical Fuel pump working on the end of your Cam Shaft, where the Clicking would come from.
Can you have someone crank the car over as you listen and/or feel for the pump to work, you will probably need to take the plastic cover off the top of the motor to check.
Everyshadeofblue
San Diego, CA
2013 Buick Regal GS
Well, the verdict is in - fuel pump. $1,400! My CPO expired 3 weeks ago. I spent $2700 on a GMEPP extended warranty but I have not driven enough miles yet for it to go into effect. This really sucks!
Everyshadeofblue
San Diego, CA
2013 Buick Regal GS
Is there a relay for the fuel pump ? I would replace that first if anything.
Not sure.... I will ask! The problem is intermittent right now. It mostly does not start but will occasionally. I wish I could milk it another 1,000 miles until my warranty kicks in but that isn't plausible.
Zeroboostbuick
312
S.W. Ontario Canada
Look in your manual and see where the fuel pump relay is located. Take the relay out and inspect it to make sure it doesn't look funny or the terminal it plugs into ldoesn't ooks funny. Corroded, slightly melted, or anything out of the ordinary.
See if there are other relays just like it that don't operate something important like ignition etc... and try to swap it with the fuel pump one to see if if it solves the problem.
stoopid
205
Las Vegas, NV
2017 LaCrosse 1SL
That doesn't make any sense. The point of the extended plan is to protect you when the warranty expires. In all my years dealing with cars (mostly new) and car forums, yours is the first time I've ever heard of such a thing. I would call the GMEPP people to confirm a number wasn't entered wrong in the system.
stoopid
205
Las Vegas, NV
2017 LaCrosse 1SL
This is a good idea, my limited experience with pump failures is that they pretty much work until they don't. Having them work intermittently points to something else IMO.
Everyshadeofblue
San Diego, CA
2013 Buick Regal GS
The GMEPP warranty I bought had a 30 day AND 1,000 mile period until it kicked in. It's been well past 30 days since I purchased it but it hasn't been 1,000 miles yet. I put very few miles a year on my car and haven't hit 1,000. The policy makes sense. My car breaks down and I buy a warranty and let it sit 30 days - I can see why the mileage clause is in there too.
It's my own fault for not buying it sooner. Lesson learned - buy any extended warranties with a 2 month buffer before your factory warranty expires. If I had done that I would not have been in a period where I had NO warranty at all. I thought I wouldn't need it then. Oops. Lesson learned.
Jeff
CLE12GS
146
Cleveland
2012 Buick GS
Mechanical, runs directly off the CAM Shaft. The 2.0 is a Direct Injection and has pressure above 200psi. # 8 in attached figure. Fuel Pump Control Module 20Amp Fuse is located in slot 67 under hood fuse block.
CincySpeedRacer
Cincinnati
2013 Buick Regal GS 6M
Had my high pressure fuel pump fail on Wednesday, just under 59k miles. Dealer quickly diagnosed and fixed today: $1158 plus tax. This thread made me confident they’d made the correct diagnosis as I experienced the exact same symptoms. So much good info in these forums. Car now back to usual peppy self, although my wallet isn’t quite as peppy.
Everyshadeofblue
San Diego, CA
2013 Buick Regal GS
Glad you got it fixed and the problem is solved! I haven't had a problem since I spent nearly the exact same amount as you. It shouldn't fail this early - boo on GM.
