HELP !!!!!!
Mongo5894
Park avenue
I have a 93 Buick Park avenue with a 3.8 and I'm having a problem with it when I stomp on the gas it has a little bit of hesitation and when I let off the gas it will die and has no acceleration and I replaced the fuel filter, spark plug, spark plug wires, fuel injectors, fuel pressure regulator and the fuel pressure is about 35 psi and it still runs like crap so if you could help me that be awesome
Alan 55
84
Florida
There are a number of things that could be wrong but one thing that leaps out to me is the fuel pressure of 35 psi. This is far too low in my opinion. I do not have a factory service manual for a 1993 but my 2001 specs are as follows: 53 to 59 psi. I think that the 1993 would be close to this number. Perhaps someone could assist who has a FSM for a 1993.
Mongo5894
Park avenue
The spec in a Hayne's manual for that year is 40-43 PSI. I don't think 35 is good enough, but with a new fuel pump it should run like new.
Ok I'll try that thanks
Mongo5894
Park avenue
Ok thank you
Pedal Commander
