Help
264
There were two options offered in the '95 4T60E, one with an 3.06 final drive ratio, and the other with 2.84. I would suspect you have the latter. You need to look at the SPID code on the spare tire cover to be sure. Do you see an FW2 (Ratio: 3.06) or the F17 (Ratio: 2.84)? What is the trans tag code?
