How much oil does your series ii 3800 consume?
109
1998 Buick Park Avenue
How much oil do your NA and FI 3800 burn?
So, I recently got my 99 park avenue ultra, and it appears to be burning some oil. It appears to be a quart 1000 miles. However, I just replaced the pcv valve and its either the original or pretty darn old, because it didnt have hardly any shake to it. And Im fairly convinced it was held open and my intake was just sucking oil in slowly over 1000 miles, so my oil consumption may be lower or none.
My 98, bless her soul, doesn't burn any oil at 170k miles, and if it werent for the junked suspension I would still be driving her.
With a motor with 204000 miles on it, it seems to be doing pretty well even if it burned that much. Soon, I will be doing a fresh oil change with high quality synthetic and that could help, too. When I do that I will get my oil pressure sensor replaced. What kind of psi readings should I expect on a 3800 supercharged?
433
1 quart every 3000 miles is within the window of "normal", but if it starts gets excessively higher it may be something to consider to look into.
179
The most common problem for excessive oil consumption on a higher mileage Series II engine, would be the valve seals. Been there, done that and no longer an issue!
Alan 55
Florida
My 3800 has 107,000 miles and consumes about a quart every 1500 miles. Concerning the valve stem seal replacement is this about the mileage that replacement is needed?
179
It is not about the mileage, but what kind of oil syenthic/dino & if regular maintenance was performed. You have high oil consumption @ 1500-miles and it will eventually kill the CAT, if it has not already. A good test of the oil seal leakage, is to start the engine and let it idle for 5-10 min, then accelerate rapidly to see if you have blue smoke from the exhaust. If you do see blue smoke, you have a valve seal problem.
179
how did you go about fixing yours? Pulling off the head and cleaning them up?
I went a little bit further than "pulling the heads and cleaning them up" with my sons help. We decided to install new ehaust valves, seals, valve guides, LSI beehive valve springs, high lift rockers, head deck angle cut -.020, complete S/C rebuild front to rear, and other improvements along the way. The bottom end was perfect and did not require any rebuild. That was about 40K-miles ago @ 180K and has now over 220K on the clock. The engine still now only consumes less than 1/2-qt in over 3k-miles with Mobile-I oil.
138171381813819138201382113822
1382313824
Very impressive. Your unit is very robust and thats good oil consumption, probably just your rings but its negligable to be honest. I like your plug wires. Have you considered making more of your engine red? Like painting the valve covers or the supercharger?
109
Then you need to downgrade to blue spark plug wires and black coils!! Im joking haha but I understand. I always liked the grey finish on the 3800. My series 1 has it and so do my series II cars.
I do like how clean your reservoirs are. My washer fluid reservoir looks pretty nasty and my coolant AND my coolant reservoir are nasty...
Also.,.. is your coolant european blue? I dont know if my monitor or the photo makes it look blue but I personally want to put the pink stuff in once I get to that point.
179
I replaced both the washer fluid & coolant reservoirs several years ago from RockAuto and use only Prestone green coolant in the cooling system. Green & blue look a lot alike on different monitors. :giggle:
