How To: Add Heated Steering Wheel Option
mjspiess
After lots of research and some trial and error, I was able to retrofit a heated steering wheel into my wife's 2013 Buick Encore. This mod should work for any 2013+ Buick Encore. This thread is more of a proof of concept. If the demand is high enough, I will sell individual kits that will be 100% plug n play for $350 shipped. The kit would include a used black pre-wired Buick Encore Heated Steering Wheel with an OEM cruise/heated steering wheel switch installed on the left side of the wheel. A new clock spring is also included along with a custom power harness that taps into the cigarette lighter fuse in the driver side fuse box. You will re-use your current airbag.
This kit is great for someone that cares more about functionality and doesn't mind a used steering wheel with some signs of use, minor scratches, etc. Also to note, the new OEM cruise/heated steering wheel switch will illuminate WHITE. If the rest of your button back lighting is blue like my wife's 2013, this may bother you. Lucky for us, it does not.
This kit should be installed by a professional. However, with some basic tools and DIY skill, this kit can be installed by yourself and/or with a friend's help in less than 3 hours.
Basic Tools Needed
Small skinny flathead screwdriver
Phillips Screwdriver
Breaker bar or impact wrench with 2.5" extension for steering wheel bolt
7mm, 10mm Deep Sockets with ratchet
T-50 Torx that fits on your breaker bar/impact wrench
Needle nose pliers or a small fuse extractor
Steps:
  1. Turn steering wheel to the left
  2. Disconnect negative battery terminal
  3. Remove airbag from the rear with small screw driver and unplug
  4. Remove steering wheel bolt
  5. Unplug wire harness from clock spring
  6. Remove steering wheel
  7. Remove single screw from lower steering wheel cover
  8. Remove lower knee panel. There are 3 screws and lay cover on the floor because OBDII port will still be attached.
  9. Pull up from the upper steering wheel cover and the two covers will separate exposing two more screws holding the lower cover on. Remove these screws.
  10. Remove two upper clock spring wire harnesses. The airbag side is a two stage plug and the red clip needs to be removed first.
  11. Remove the four clock spring screws
  12. Remove the lower clock spring wire harness with a small flat head screw driver
  13. Swap the clock spring module from YOUR clock spring onto the NEW clock spring. There are 4 tabs that need to be depressed in order for the module to slip off.
  14. Find the fuse box up under behind the "coin" tray and locate the 20 amp lighter fuse. Remove the 20 amp fuse and place it into the custom power harness. Plug in the custom power harness into the 20 amp lighter spot and route wire up along main wire harness going to the clock spring.
  15. Secure the ground wire to the 7mm screw holding down trim near the hood release
  16. Pull centered peg from new clock spring and turn to the left 180* and install the clock spring with the 4 screws
  17. Plug in two upper clock spring wire harnesses
  18. Plug in the lower clock spring wire harness
  19. Plug in custom power harness to clock spring harness
  20. Replace the lower steering wheel cover center screw and the two upper screws. Snap the covers back together.
  21. Install the new heated steering wheel upside down by feeding the airbag and heated steering wheel harnesses through the steering wheel.
  22. Plug in the clock spring and power harness to the heated steering wheel module. Secure the wire under the hook on the steering wheel.
  23. Replace the steering wheel bolt
  24. Replace the airbag plugs and airbag
  25. Replace negative battery terminal
  26. Enjoy your new to you heated steering wheel!
KevinJ
Contributing Member
337
70
Ohio
Kudo's for even attempting this mod and the excellent instructional write up.
But I'm pretty sure I would have just told the wife to put on some gloves....
mitchflorida
Active Member
628
185
South Florida
You can get some really nice leather gloves for $350.
mjspiess
True, but do they heat up? :) I'm certainly not set on $350 for a kit. What would you be willing to spend for this upgrade? The price difference between the cheapest Encore 1SV trim and the Essence trim, which is the lowest trim that offers the heated steering wheel, is $6k. Granted, that $6k comes with a slew of other upgrades, it's still a lot of money. With that in mind, I figured $350 isn't all that bad?
Epsilon
Various
OP, do you have any drawings or photos of the custom wiring harnesses you built? I assume you got the cruise control functioning correctly too? I started this same project last year. I got the steering wheel to heat up, but the power light never lit up, and the cruise control was not functional. I had a heck of a time trying to figure out how to reconfigure the wiring to get everything working. I ended up uninstalling it and want to give it another go now.
Wag0n
47
2018 Regal TourX Essence | 2021 Envision Avenir
Would this be the same process for adding a heated steering wheel into a 2020 Encore?
handydoctor
None
Great work. Is heated steering wheel an option on 2013 Encore? I am trying to do the same for a 2013 equinox. It's not an option that year and I think it will be quite some work.
Smoothsailer717
45
2019 Encore
It's 1 of the best options on cars today, Seems like a lot of work But it's really not that much.. Sounds like the hardest part Is getting the steering wheel in the right alignment on ReAssembly. Sounds like this is a 1 person job, I'm not sure why the instruction say you need 2 people
13redgs
2013 Buick regal GS
Digging up a somewhat old thread but do you have any kind of schematic or wiring diagram of your harness? I'd like to do this to my regal and curious how hard it would be.
