How to Install A/C Compressor Refrigerant Cut-Out Switch
GunnyP
A Regular
58
Cleveland, OH
Buick Park Ave Ultra 1993
Thread starter #1
Installed a re-manufactured A/C compressor last June, but never finished the job as winter overtook my efforts. Turns out that I had failed to install the compressor-mounted refrigerant high pressure cut-out switch. After 12 hours removing the starter and finally getting the compressor out of the vehicle, I am left flummoxed by how to install this cut-out switch.
The problem is that the re-manufactured compressor, although it does indeed have a snap-ring at the location of the cut-out switch, once that snap-ring is removed there is a metal cap beneath covering the hole into which the cut-out switch should be inserted. One would think that the snap-ring was holding this metal cap in place. But I can't figure out how to remove this metal cap. I've tried prying at the edges with a screwdriver, box-cutter and scalpel to no avail. I've struck the cap a few blows with a chisel but stopped as that type of mad overreach will likely do more harm than good.
The re-manufactured compressor is identical to the old except that the old has the refrigerant switch mounted. The old compressor refrigerant cut-off switch's plastic housing had cracked else I would have attempted to salvage.
Any clue as to out to simply remove this cap?
One other thing and the only notable difference between the old and reman compressor is that the reman has a thin metal cap covering the entire bottom(?) - well, perhaps better described as covering the clutch - that portion that juts out past the serpentine belt pulley - and is held in place by three diminutive screws. One of the screws has already fallen off. Was this metal cover there just to protect the clutch during transport. I am fearful this cap will vibrate loose and end up destroying the serpentine belt pulley system.
I can add picture for clarity if needed.
GunnyP
A Regular
58
Cleveland, OH
Thread starter #2
The local garage helped me out with this. After banging away at the cap for several minutes as I had done, he shifted to a prying tool. Turns out that the cap was actually a solid plug that had to be pried out.
Pleased that the garage mechanic was just as uninformed as I.
For the future befuddled here is a picture of the plug beside the inserted cut-off switch.
