How to remove college sticker from glass
imidazol97
Top Dog
1,660
127
How can I remove a 4 x 5" plastic college sticker from the inside of the rear window without damaging the defogger line?
I've tried WD-40 and it's not doing much to release the adhesive.
NFortin198
23
2002 Buick Century Custom 3.1 2002 Buick LeSabre 3.8
Use a hair dryer to heat the sticker and soften the adhesive, while it is still hot/warm peal the sticker off. A heat gun will work as well, you just have to be a little careful with it so you don't over heat the glass or melt/burn the interior. Then use Goof Off or wd-40 to clean up any adhesive left over from the sticker.
gnhbodyguy
03 Limited & 04 Custom
Soak it with Gumout and let it sit for a while. Then try peeling or scraping.
NormT
Turbo-4 power!
1,535
182
OH-IO
2018 TourX
Try heat first from a heat gun or hair dryer. In the sun helps preheat. I'd do heat before petroleum based stuff.
