How to remove the center vent on a 2007 Buick Lucerne
jlaroche
North Charleston
Buick Lucerne
The center vent in my Lucerne has developed several cracks around the edges of the center vent on the dash. I would like to remove and replace it, but I don't want to damage it further. Any Ideas? Thanks
1,319
I assume you are referring to the part below. Not sure if the vent area is available alone, but the entire trim bezel is on eBay. I pulled my entire dash out and can't recall if this can come out by itself or if the pad needs to be removed. The one thing I do remember is that the emergency flasher button has a pin on both sides inside the vents that need to be pushed in at the same time to release it and I think it may have been held in with screws at the top again it was a while ago. Hope this helps.
