How to replace side view mirror on 2012 LaCrosse
richardnewton
180
38
I did passenger side mirror a few months ago. Thought I posted a summary but must not have. A few tips I can remember:
- The GM OEM mirrors and housings are superbly engineered. Don't get aftermarket; either buy OEM from GM or from junkyard. OEM mirrors also have a lot of foam to reduce road noise.
- Used OEM complete mirror cost me about $75 shipped.
- There are glass replacements if you just want to replace the glass. Removing the glass takes extreme care or the glass will shatter so use caution.
- If you are just replacing glass, non-GM mirrors may be lower quality. I replaced outside mirrors on another car and the thinner non-OEM glass was a bit wavy...rather irritating.
- There are a large number of replacement mirrors based on car options, color, side, lights, alerts, etc. See RockAuto link to help you make right choice.
- Replacement of the mirror was quite easy and I avoided taking the entire door apart. See buickforum links below
Replace mirror turn signal on 2012?
https://www.rockauto.com/en/catalog...542,body,outside+mirror+&+glass+assembly,1304
