How To Replace the Climate Control Bulbs
Thread starter #1
23
2001 Buick Century Custom
This Was done on my 2001 Buick Century Custom And I would say that Process would be the same for any gm running this same Climate Control unit (non Digital unit)
NOTE: You Must Be able to Solder pretty well To Do this the traces are very small
1 Remove the lower trim Ash tray trim panel there are two screws on far bottom and top side just snaps off
2 the Climate Control Unit is Mounted with two screws one on each side
3 Remove the electrical connectors and vacuum hoses just make sure you disconnect the vacuum only part I did not and had three springs and a ball bearing,copper plate to tend to going back together just removing the vacuum part is the two tabs farthest from the unit
4 remove the fan speed control switch two screws
5 Remove the vacuum valve two screws Careful There are three springs under it you will need to hang on to for reassembly
6 Remove the four case screws and open case careful to hold the control face down so buttons do not fall out less work on reassembly
7 Remove board from case by gently prying the board passed the tabs in case
8 now you can position the board (See Pic Below) there are 10 bulbs on board they have a blue rubber filter cover on them
9 Now You can replace you bulbs take you time and make sure polarity is correct or bulb will not work (LED'S Only)
I have went through the process and tried to show where the positive is for each base to make it easier If needed I Found my test light worked the best the gator clip to cigeratte lighter ground worked good. Not much steel for ground in that area the needle point on test light worked good for the close quarters to each other
Of Course I used Leds and all though you can change colors at this point just note that colors will effect the red and blue of the temp Indicator
1229180925 - Copy.jpg 1229180907.jpg 1229180907a.jpg 1229180921.jpg 1229180926.jpg 1229180944.jpg
1,412
364
Perfect write up, I'm sure it will get used or reposted more than a few times. As the age of some of these cars are getting up there more owners will be having this problem.
Thread starter #3
23
Yeah every dang one of them, ten bulbs in that thing and all was out I do not get GM's BS they got leds for half the gauge cluster and the backlights are standard 194 bulb's and the same with the climate control the rear defrost and A/C button lights are led but the back lights was standard bulb WTH GM
364
My 95 Lesabre have all disappeared, but I'm to lazy to yank it out so I'm using "The Force" to hit the right button LOL. Again it's nice you spent the to document it for others.
Thread starter #5
23
I tried I am By far not The best person to try and explain something like this but I have no problem doing it. Its just telling someone else how to or to try and remember to take the right photos I get caught up in the task and forget to take photos I done good to remember to get them LOL and yes that took me 1.5hrs to do that and Thanks
ledzilla
10
2001 Century Custom
I'm glad you did this write-up. I've been looking for one for over a year for this particular control panel. The only lights I have left working on mine are the indicators for the defroster and the AC. This should be made into a sticky.
Thread starter #7
23
Yeah I kept looking for one to give me a heads up before doing mine never did find one so I tried to make up my own as I went
