I had a service stabilitrak message appear along with a constant ABS light yesterday
Paco
2013 Regal 2.0 Turbo
Replaced three wheel bearings so far just wondering if I should suspect something else the noise is not the same wheel bearing failure noise. Any ideas
Paco
Thanks I will check that .I just meant the blender sounding noise when your wheel bearing is worn out. Would speed sensors be warranty?
BoostedRegal2.0
238
Speed sensors are covered under the bumper to bumper warranty but it's expired on your 2013 Regal.
dbruce
12
2012 Buick Regal GS
Just about everything sets those warnings off. Had a brake fluid leak....did it. Had the solenoids go....same.
Zeroboostbuick
347
S.W. Ontario Canada
The wheel speed sensor is a magnetic pickup and not a mechanical reluctor ring like it used to be. So any metal debre will mess it up and even a buildup of crap might affect it.
Check out this Bulletin... PIC5428G
2011-2017 Regal is on it among many other models.
Paco
Thanks so much
dbruce
12
2012 Buick Regal GS
You can get to it from behind. Best bet is to remove the rotor to give you room. Not needed, but helps.
