I need some help..:-) 1999 Park Avenue Struts
yankee56
1999 Buick Park Avenue Base
1) What is the torque setting for the lower strut bolts that attach to the knuckle?
2) I've ordered a new camber bolt as well, and need to know what goes where as far as washer layout in pic. Mine does not have one of them? The new one IS the correct for sure. TYVM! camberbolt.jpg
192
23
2) I've ordered a new camber bolt as well, and need to know what goes where as far as washer layout in pic. Mine does not have one of them? The new one IS the correct for sure. TYVM! View attachment 18024
I've always used "tight" for that bolt. But if you are installing cambolts because your front end has wear, it might be sensitive to torque. I don't know how that works. You probably need it aligned. Maybe have an alignment shop do it?
