I Removed the Plastic Cladding Trim on the Tourx
Zeroboostbuick
434
S.W. Ontario Canada
looks wise, I prefer the cladding on.
But with the cladding, water will probably hang around much longer, keeping the area moist and more likely start rusting earlier.
Once the Rust starts taking shape, you can put the cladding back on and hide it !
SweetWafer
251
134
2018.5 Regal TourX
Nice job! I thought I might want to do this to mine, but I'm not up for replacing the bumper to finish it off.
BrianCoasters
108
Greensboro, NC
2018 Regal TourX Preferred, Sport Red
Looks good so far! Really curious to know how much the replacement parts cost.
Imp
Soon
Is the black portion on the bumper not removable? Looks like just the last trim that goes down to the black.
gobluetwo
A Regular
170
80
IL
none
He mentioned in another thread that the black pieces on the bumpers are molded in and not removable. OP is apparently planning on replacing the entire front/rear bumpers.
tinmanwpk
n/a
If you are going to the trouble of removing your bumper why not just remove the existing pieces and cut off the remaining piece of cladding with the bumper assemble off of the car?
Bimmer
3.8L Member
275
107
Humboldt County, CA; or Germany
Not yet...
Dang, that looks terrific. Did it just pull off the fenders?
The front bumper looks a little weird, but I'd be tempted to just paint it (I'm looking for a white TourX).
Skynet
37
Augusta, GA
Insignia Country Tourer
What build up of water are you referring to? Fenders/bumpers without cladding will not accumulate water. Maybe I'm missing your point.
tinmanwpk
n/a
And then he says when the rust starts you can put the cladding back on. I'm confused.
Once the rust starts it looks ugly. You can cover it up by replacing the plastic cladding you had taken off pre
wi_badger
A Regular
111
27
Any updates on this?
crush157
2018 Regal Tour X
Wondering if that last piece on the front wheel wells can be removed as well. If the OP would post how it was done, that would help too...
1612202
68
New Tourx Owner
If you look at the parts diagram online on GM Parts dealers it shows the front bumper cover has a separate cladding trim piece. It also shows that the bumper cover has ridges where the cladding goes. The diagrams are drawings not pictures so we can only assume that it could be an easy removal and reveal.
Should removal of cladding be known as De-Aztecking?
DasWagen
58
2018 Tour x
Subscribed for more results on the decladding process. I also like the Opel look better. And how do we lower the ride height down the couple inches Buick decided it should be raised?
DasWagen
58
2018 Tour x
I have the side skirts on the way and I plan on buying the bumper too
I'm about to pull the trigger on a black Tour X. I don't care for the cladding either. I like what you've done so far. I wonder if the piece circled in my pic could be removed and look as clean as the wheel wells? If so, I think I could live with removing all of the wheel wells and replacing the rocker trim with just the painted rocker pieces. Not too much $s either. Please keep us updated Hoffmantre.
