Installing tach
thattrainguy1
1970 buick skylark
I have a 1970 buick skylark with a 350-4 engine in it. is there anyway to install the stock tach without dropping the dash and how do you wire it to the power?
513
This should help in identifying what you have and wiring it in. Yes you will more than likely have to at least pull the dash bezel out as most older items installed from the rear, can't confirm on yours. Most GM I've had it was a bezel, clear lens then a gauge pod which had the individual gauges you could remove. If you do yank it out it's good time to replace the lamps back there.
Need Help Installing original Dash Tachometer in my 1972 Buick GS
