Intermittent 3rd Brake Light Operation
Blu05
31
Thread starter #1
Back with another thread, i own a 2005 lacrosse. Up until recently my 3rd brake light (LED of course) doesn't work when i hit the brakes. Now i've noticed in super cold weather anywhere from 5° to 20° degrees it works but as it gets warmer including the interior of the car it doesn't seem to work properly. Being LED it'd have to be replaced as a whole assembly. But i have confirmed it's an iffy connection somewhere because they light up sporadically. Any ideas?? Bad connection?? Thanks!! P.s. my regular brake lights DO work.
PurpleHaze
3.9L Member :)
229
22
Lawrencvile, Ga
It sounds like you may have to just replace the third brake light assembly. My 2006 Cadillac Escalade third brake light just stop working and I had to replace the unit. Very common issue for 2002-2006 GM SUV's.
I assume the same for your 2005 Lacrosse, however it would be a wise move to check the connections before buying a new one.
