iPhone Ringer Volume Automatically Lowers to Minimum
wagonlover56
32
Silicon Valley CA
When I first got my Tour X (April 2018 build) at the end of March, I posted a list of "oddities" I'd noticed early on one of which was that every time I start up the Tour X with my iPhone 6 on me (which is always), the ringer volume on the iPhone magically lowers itself to the minimum setting which is where it stays until I manually raise it again. One person responded to my original post and said "mine does that too" but I was hoping someone has a solution OR perhaps has a newer iPhone that doesn't do this. Your feedback on this issue would be greatly appreciated! I do have the latest iOS on the phone and all updates.
trflesher
11
2018 Buick Regal Sportback
I assume you're connecting your iPhone via bluetooth? I'm only speculating since I have an android device paired to my Regal ... but I have seen cases where when bluetooth pairing happens, it "remembers" or sets a volume consistently with that paired set of devices. For example, on my android and Bose speaker at home .. even if I had my "media" or music volume up full blast when not connected to blue tooth .. it would lower it to a previously known volume when connected again to the Bose. Again, I'm just speculating, but I've seen similar behavior. What I can't answer; unfortunately, is how you tell it a different volume to default to, or not to auto-adjust. Hopefully someone else has experience with that.
wagonlover56
32
Silicon Valley CA
Yes - this is strictly a bluetooth connection to the iPhone and I am 99% sure that when it was originally paired, the ringer volume on the phone was set to the highest setting. Maybe this is just another example of the Android based infotainment system not "playing well" with Apple products.
Ctrcbob
286
Regal Tour-X
Yours is working correct. If you get a call while in car, you will still hear it loud. Once you get out of car, your phone ringer goes back to your original setting.
At least that’s how it works with my iPhone 5s and my iPhone 5.
wagonlover56
32
Silicon Valley CA
My phone ringer does NOT go back to the original setting when I get out of the car. That is the problem. It always defaults to the lowest possible ringer volume and I have to manually reset it back to the loudest ringer volume setting.
