Just got this 2005
Thunderhawk09
9
2001 Buick Century Custom & 2005 Buick LeSabre Custom
I bought a Buick century in November 2018 and really like it so when then opportunity came up for a deal on a 2005 Lesabre I was all over it put plugs, wires, Battery, head gasket set & a new intake Manifold gave 350 for the car and 540 in parts and got to give her a good cleaning wax and all this will be a slick car and only have 890 dollars in in it woo hoo0406191248.jpg56180232_10214657228008894_3871087292701474816_n.jpg56232293_10214657225408829_1664580645046714368_n.jpg56531121_10214657227688886_4334997271667015680_n.jpg
Thunderhawk09
9
upon deeper investigation found motor bad possible bad piston on cylinder 3 with a psi test of only 30psi I decided to go the better route and just replace the whole engine worked all day yesterday came home rest till 8:30 pm went back to shop and 9pm started my auto repair 3.8L swap previous owners run it hot and burned the old 3.8 up the car has 145k on it the new engine 90k 5am swap was done but found a bad Injector on cylinder 4 changed it out all good now 6am it got a wash job for the fist time in over a year of sitting 9 hrs under the hood and now its on the road again love the ride its way better than my century paid 350 for the car total now just a little over 1,100 cool 0413190852_HDR.jpg0413190852.jpg
Cstoliker
Very nice! And last model year for the Lesabre after 46 years.
Bad luck on motor. These series II 3.8’s are virtually bulletproof with exception of intake plenum. Very rare to find a catastrophic failure unless you run with no oil and even then, they don’t die easy.
Things you’ll have to watch: These cars wheel bearings fail often and brake rotors warp about twice as often.
Electrical system runs around 15v all the time. And the auto headlights are almost always on. As a result you’ll go though headlights fast and even more annoying, the backing lights on the interior buttons blow out.
264
upon deeper investigation found motor bad possible bad piston on cylinder 3 with a psi test of only 30psi I decided to go the better route and just replace the whole engine worked all day yesterday came home rest till 8:30 pm went back to shop and 9pm started my auto repair 3.8L swap previous owners run it hot and burned the old 3.8 up the car has 145k on it the new engine 90k 5am swap was done but found a bad Injector on cylinder 4 changed it out all good now 6am it got a wash job for the fist time in over a year of sitting 9 hrs under the hood and now its on the road again love the ride its way better than my century paid 350 for the car total now just a little over 1,100 cool View attachment 15058View attachment 15059
Congratulation, and love the physical endurance you seem to have to restore that car, and it should be good for another 100K with proper engine/trans maintenance!
Thunderhawk09
9
as for the brake rotors I am getting ready to add power stop slotted and cross drilled rotor. And what is up with GM using Cranberry red base under there white cars the paint pealed on the bumper and its cranberry red under the white talk about a bad paint spot standing out like a soar thumb
Thunderhawk09
9
Had to add a little spruce up under hood too lol cant even tell that motor was not the factory installed one and its clean now 0426191124a_HDR.jpg
Thunderhawk09
9
Crutchfield said the Kenwood ddx595 i had i my century would not fit the lesabre wrong same cutting I had to do in the century that they told me about it was the same thing on the lesabre now I got my good radio in it 0427191856.jpg0427191923.jpg
