key stuck
Thread starter #1
Bruick
Riviera 97
i have a 97 riviera, the key is stuck and wont go past off, to lock position. I wiggled shifter and button, is there a shifter interlock? how can i fix this problem? The key is stuck in the ignition. Any help from the knowledge base out there? thanks fellas.
Zeroboostbuick
240
S.W. Ontario Canada
There should be a key release button.
Also if I remember correctly, I had the same problem in a 98 Regal. There is a hole under the steering wheel column, and inserting a pen released the key. The hole had a plastic cover that had to be pried off with a small flat blade or knife.
So I asumed some spring or something must of broken... I just duct taped a little screw in the hole so it maintaned the tension on whatever it was to remedy the issue.
