Keyfob not recognized
Buickruss
Indiana
2015 GS AWD 87 TType wife's cars. She lets me work on them
2015 GS has been showing the above message....also sometimes wont start car or unlock Doors.......dealer says the fobs arę bad and need to be Replaced.
I has battery tested to confirm its good. Recent new batteries in the fobs.......any others tests to do so we know for sure?
487
Did you test the key fob batteries with a volt meter? I read they are new.
Did the dealer actually test anything or just made that statement. Hard to believe both fobs would go at same time.
487
Did you tell them the second one doesnt work either and they still insisted both failed at the same time without checking the second one? Seems like you have to tell them you have grave doubts that they both failed simultaneously.
Buickruss
Indiana
It does have the original battery. I had 2 parts stores check battery and charging system, both said batt was good
atomicbee
13
Southern California
2014 AWD PR 2
I have never changed my Key fob batteries since I purchased the car new in Dec 2013 BUT I did have key fob problems when the battery was acting up about 3-1/2 years after purchase. I got a new battery under warranty and magically the keys worked again. Below is some Buick owners Manuel information regarding Key fobs
If the transmitter battery is weak or if there is interference with the signal , the DIC may display NO REMOTE DETECTED or NO REMOTE KEY WAS DETECTED PLACE KEY IN TRANSMITTER POCKET THEN START YOUR VEHICLE when you try to start the vehicle. The REPLACE BATTERY IN REMOTE KEY message may also be displayed at this time.
Place the recognized transmitter(s) in the cupholder. The cupholder liner will need to be pulled out to access the transmitter pocket. 2. Insert the vehicle key of the new transmitter into the key lock cylinder located on the outside of the driver door and turn the key counterclockwise to the unlock position five times within 10 seconds. The Driver Information Center (DIC) displays READY FOR REMOTE #2, 3, 4 or 5.
3. Place the new transmitter into the transmitter pocket with the buttons facing up. The transmitter pocket is located inside the center console cupholder. 4. Press the ENGINE START/ STOP button. When the transmitter is learned, the DIC will show that it is ready to program the next transmitter. 5. Remove the transmitter from the transmitter pocket and press K. To program additional transmitters, repeat Steps 3–5. When all additional transmitters are programmed, press and hold the ignition for 12 seconds to exit programming mode. Reinstall the rubber cup liner
529
I recently found out that all brand of fob replacement batteries are not created equal as far as thickness! I had one fob fail, then the other getting weak. Replaced all batteries with new (same number) but different brand and both fobs failed! Come to find out, there is a difference in the thickness of the batteries between brands and the thinner ones (outsourced) would not work, or make contact with the printed circuit board in the fob. Do you know what brand were originally installed? If you can find that that info, get the same name brand!
CoyoteEcotec
55
2016 Regal AWD T
That’s great information to have. Sorry you had to find out the hard way but glad I don’t!
Buick Gang
2017 buick regal gs
I'm having the same issue with my 2017 buick regal gs. The car will unlock just fine then you get in and push the start button and it says that there is no key fob detected. I have 2 keyfobs and both have the same issue. This problem has only happened 2 times in the 6 months that we have had it and if the car sits for 20 mins or so all of the sudden it works just fine.
oldassz
Edmonton AB
16 Regal GS
I'm experiencing an issue with my 16 GS currently and the message displays saying keyfob battery is low. What the dealership thinks is happening is my rear park sensor modules are corroded and feeding back to the computer causing a whole bunch of issues ( reverse lights on when driving forward, "shift to park" message, low battery on keyfob message, car continues to run after hitting start/stop button ). There is an updated module available from GM to correct this particular issue. It's common on the acadia/traverse/enclave platform also. I have a close friend with a 16 acadia and this was causing similar issues for them. I hope this helps.
