Keyless Entry Remote Plug location
KRV
1996 Roadmaster base sedan
My '96 Base Sedan has the option AU0 but I don't see the plug to program my key fob. Exactly where on the left side of the trunk should it be? I pulled all the insulation back.
Full Member Since 2005
9,397
1,477
SE
It is located in the upper/top of inner fender panel. It is hard to see, but you can feel a wiring harness up there and there should be a wire coming out of that harness with a terminal that you jumper. Good Luck!
KRV
Thanks!
Catov8
roadmaster wagon 1996
hay un tutorial en YouTube de un sedan te puede servir..
9,397
1,477
SE
Translated;
There is a tutorial on YouTube of a sedan that can help you.
