Knocks hard twice in "R"
LouK
When I put my 1998 Buick Regal (3.8L) in Reverse to back up it make a hard, loud double-knock that sounds like it's coming from the Transmission area. Any info would be greatly appreciated.
725
Things that might make this noise:
Transmission mount
Subframe mounts
Engine movement, engine mount problems
Sticking brakes
There could be something inside the transmission which is causing this sound. Eliminating external possible areas first, these are mostly visual inspection, could be the route to start with.
LouK
So, I'm impatient. I contacted an ASE Certified Mechanic who tells me that it could be one or more of 4 things; delayed torque converter engagement, reverse servo bands are stretched, vacuum modulator vault and/or low line pressure to reverse solenoid. All of which are located in the transmission. Does this sound like I'm in need of a tranny scan for fault codes?
725
Full trans scan probably would be a good direction but I'm not sure how much detail other than it would give a code, again we can't hear, feel or see the problem so it's best guesses from a brief description. The mechanic may have more experience in this description, but he also has it at 4 possible problems so until it's inspected it could be any of the inside problems.
