Lacrosse Touring package rear shocks discontinued. Anyone know of any sources?
goatbuick
Louisiana
2010 Buick Lacrosse CXS
Hi all,
New member here. I have a 2010 Lacrosse CXS with the 19" wheels and Touring package with the electronic damping on the rear shocks. My shocks are shot. I have tried to find replacements to no avail. All of the dealerships here say that the shocks are discontinued and that they are unable to order them. They say that there is zero stock showing in any dealership inventories in the whole country. I have tried crossing them with numerous local parts houses as well as ones online with no luck. There is an electrical connector on the shock and from what I can tell, any sensor etc is integrated into the shock itself.
I have called AC Delco whom I thought were the OEM supplier but apparently we not, but they could not provide me with any further info. My local guy spoke at length with Monroe and was told that they couldn't provide anything, not even a conversion.
According to my VIN, the specified shock part numbers are:
84336155 for the rear left
84336156 for the rear right.
The codes associated with the VIN are;
F45 --- Real time damping
GNA --- Front struts
GNE ---- H-arm rear axle
VRN ---- Value Added Rear suspension
Any help with finding replacements for these would be greatly appreciated. At this point the car doesn't feel particularly safe to drive on a rough surface. The rear tires are chopped from the bad shocks.
The car is essentially parked because of the lack of availability of the rear shocks. Thanks for any input or info, Hope everyone has a great day!
Chris
goatbuick
Louisiana
Hi MelsRegal. Thanks for taking the time to reply. I am getting these part numbers from dealers who are going strictly off of the VIN for what it's worth. Several different dealerships have all given me the same two part numbers (and only those two) after I gave them the last 8 digits of the VIN.
I noticed that Rockauto, Carid and a few others have part numbers that are off only by the last digit, instead of 84336155 and 8433156, they have 84336157 and 84336158. When I was on the phone with AC Delco I asked him if those would possibly be compatible so he plugged them into his system that goes strictly off of the VIN and it did not show as compatible. He stressed that nothing else showed as compatible, not even any AC Delco part numbers or those from other manufacturers. Which is how he determined that they were not OEM manufactured by AC Delco.
He said that his system showed that those two numbers were the only ones listed as compatible based on my VIN and that they were showing as Dealer Only. So he said that they were never manufactured by an aftermarket manufacturer, AC Delco or anyone else.
I asked all of the dealerships that I spoke to if anything else was compatible or if there were any superceeded numbers possibly etc and everyone replied that those two numbers (84336155 and 84336156) were the only good/valid ones based on my VIN.
I have seen some that everything else matches in terms of F45, VRN, GNE, but the code for the front struts differs, GNB instead of my GNA. Apparently GNB denotes a high performance front strut. Maybe the damping parameters have to be matched between front and rear sets in terms of how they talk to the computer etc possibly?? I have no idea what the difference could be.
Thank you for sending the link...I agree that it seems to fit the bill in terms of the car specs, I just don't know why everyone, in different parts of the country are all only giving me the numbers that they are based on the VIN. I have to assume that they are correct I guess. Thanks again so much for the input, if there is any other info that I can provide just let me know. It's hard to believe that a car that is only 9 years old has to be essentially parked because no one makes shocks for it.
goatbuick
Louisiana
Apparently the one in the link isn't the correct one, when I clicked on it, a little more info came up. It is for the 4 link suspension, not the H-arm axle and it specifies that it is for cars without real time dampening.
  • Description:
    Without awd, h-arm susp, with chassis control. LaCrosse. 3.6l. Left. Without real time dampening.
  • Applications: W/4-LINK REAR AXLE. "
goatbuick
Louisiana
Hi MelsRegal. Thanks again for the reply. I apologize, I may have looked at the wrong link, I had dozens of tabs open on my laptop and they were all shock/strut pages.
I do see that that shock is compatible with real time damping, but it also specifies that it is for the 4 link rear axle and because of the touring package, I have the H-arm rear axle, which apparently will make it incompatible.
I spoke with someone at AC-Delco yesterday who tried very hard to find something that would work and he said that no matter what part numbers he plugged into my VIN, they were incompatible.
They do actually list the correct shock in their catalog and it's listed by the GM number 84336155 and 6156, but he said that it showed as "dealer only" and that they couldn't get it and that they were not the OEM manufacturer for it, otherwise he would have an ACDelco number for it. According to him, it was only manufactured by the OEM manufacturer, (whoever that was) and that an aftermarket version was never made.
I called a dealership in Houston who is supposed to call GM and get back with me, so maybe that will shed some light on things, hopefully. Thanks again for being so helpful.
goatbuick
Louisiana
I heard back from the dealership in Houston. They checked the "engineer's notes" on the page that stated the shocks were discontinued. The engineer's notes said that the shocks were in the process of being reinstated (reintroduced into production). The dealership called GM and spoke to a tech that confirmed this. He could not say when but speculated it would be within 4 weeks.
Rich B.
81
Minot, ME
What interesting threads here and helpful. I’d imagine a separate vendor was used to provide shocks with certain operation parameters if nothing available through main sources.
An example, Ford shipped entire cars off to Car Craft for the original batch of Boss Mustang 429’s, may of been 428’s? Same with the Shelby’s. https://www.hotrod.com/articles/unbelievable-check-out-this-low-mile-boss-429-just-pulled-of-storage-after-40-years/
Pretty sure the lower option configuration for that model/year Buick can be retroed to work. Can’t picture on an assy. line major differences would be employed for minor changes, oh well......
mikeam
Hopefully he will back to you. I also have the Touring model (2013) with the mag ride shocks (42K).
MillenialCXS
2010 Buick LaCrosse CXS
I have run into the same problem as goatbuick where my left rear shock absorber is starting to fail and a replacement still doesn't exist. VIN 1G4GE5EV0AF224297. F45, GNE, GNA, VRN.
I think I have found the new part numbers but the acdelco website doesn't give me enough information to confirm this.
84545200 rear left
84545201 rear right
Everything matches and the only thing different is the description of shock absorber vs. shock absorber kit.
I have an email inquiry into acdelco and gm to determine what the replacement part number is.
Mad*Max
51
48
Toronto
Two ideas, one see if a wrecker has some from a wrecked car, second, you should be able to put regular shocks and have the tech reprogram the car to think there is no longer mag ride shocks
