Atreus21
- 0
- 1
- Buick
Hi fellas,
02 Buick Rendezvous
I put the whole car back together after replacing the thermostat housing, thermostat, and radiator, only to discover I had misdiagnosed the problem. Coolant is leaking not from the thermostat housing, but the metal tube in the lower intake directly above it. I know it connects to a heater hose, but I'm not sure exactly what it's called.
You can see it in this video, at the 31:07 mark.
Screenshot is here:
It's leaking from the connection to the thermostat housing, circled in blue above, so the question is: would mashing a ton of permatex in there suffice? Unlike the picture above, getting to that pipe in my car would require a ton of work.
Here's a closer picture from the actual car:
Would welcome any opinions.
Thanks.
02 Buick Rendezvous
Screenshot is here:
Thanks.
