Leaks on drivers side axle and inner tie rod
shornber
2006 Rendezvous CX
Are there seals on the inside of the axle and tie rods? My drivers side is showing some moisture but I don't see any active dripping and the fluid levels are still okay. Any idea what could be causing this? Attached is a picture of the driver's side axle and tie rod.
TollKeeper
15
Brighton, CO
I wouldnt worry about them. Replacing the seals causing the seepage could turn them into full blown leaks. Just occasionally take a look, and make sure it hasnt gotten worse. Otherwise, just leave them be.
Edit: I would like to add that the seepage you see there could eventually turn into a leak. or it may run till the cars dieing day.. Its a crapshoot. It also isnt broken, and there is no need to fix it.
My Aztek has a leak SOMEWHERE in the power steering system. I have to add fluid to it every -2- years! Am I going to spend 1000 bucks to fix a problem that costs me 5 bucks every 2 years? HELL NO!
